seems most people use the AP 6 paddle with the helix cover.
Yea this was what i was looking into getting but now been advised by Matt Lewis Motorsport to go with Helix/Helix due to issues with the AP, Just want peoples opinions on the Helix kit before a biuy.
I wasn't aware of that. I was looking at getting the AP/Helix kit from Matt Lewis later this month.
will keep an eye on this and see the comments, as I may be going the same way.
Yes this is correct. I use complete helix kit on mine and its fine.
just remember to have the flywheel refaced and bed the clutch in. And ensure fly and clutch assembly are torqued to spec using a little loctite on bolts.
I have just fitted the helix 6 paddle with helix cover along with a new cable as recommended by matt lewis and i am really pleased with it. Feels amazing not heavy at all.
Also doesnt seem to be juddery when pulling away. Even better than the old organic clutcj i had before. (Might be due to the flywheel now being refaced)
I've got a AP 6 paddle & helix cover from Matt I fitted that last year & did hydraulic at same time, I had fly wheel skimmed & just wanted to know if everyone has the same slight bit of judder when you pull off in 1st?? If at low revs, if u Rev it quite high & let it out it grips & yr gone.... All other gear are perfect just wonderd if this is normal with a paddle clutch???
I have got a Helix 6 paddle clutch & cover plus a new lightened flywheel with hydraulic conversion and I have never had any judder with mine so far.
