oil pressure gauge pipe
Old May 31, 2015 | 06:12 PM
griffo69's Avatar
griffo69
Default oil pressure gauge pipe
Hi all , got an autometer phantom oil pressure gauge , it came with a shitty looking ,thin, white nylon oil pipe. I ordered a black racetech pipe to fit , but the connection is slightly to small .( Very very tight to do up ) . Does anyone know of any universal fitting , black nylon oil pressure gauge pipes that would fit my autometer ? Any help / links etc appreciated
Old May 31, 2015 | 08:03 PM
studabear's Avatar
studabear
You might be able to get something at your local hydraulics factors
Old May 31, 2015 | 10:28 PM
griffo69's Avatar
griffo69
Cheers mate, May have to . After a bit of reading, the size on the fitting I need would be a 1/8npt female for the back of the gauge , May be the same for the engine side ?
Old May 31, 2015 | 10:47 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
If you use a oil filter sandwich plate the fitting size is 1/8npt the same as the gauge . Just type 1/8npt oil pressure gauge fitting kit into eBay and you should see loads . I've got a copper pipe on mine with braised ends onto the union so don't leak at all . The plastic pipe I had originally leaked so replaced it
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
dombanks
Sep 21, 2015 08:38 PM
Chopshop85
Sep 18, 2015 06:13 AM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
