Fiesta MK3 XR2i camshaft
Old May 30, 2015 | 09:11 PM
CrazyRx's Avatar
CrazyRx
CrazyRx
Default Fiesta MK3 XR2i camshaft
Hi there im new here ,i want to buythe kent cam CVH33K for my ford fiesta xr2i 1991 efi , approximately 20bhp increase they say
Applications Competition Power Band 2500 - 7000 Cam Lift(mm) 7.36mm Inlet/7.24mm Exhaust Valve Lift(mm) 12.14mm Inlet/11.63mm Exhaust Duration 290 Deg Inlet/ 285 Deg Exhaust Timing 36/74 72/33
now the question is :''have someone put this cam on his car?'' i know if i put this cam the idle will be irregular .
Old May 31, 2015 | 12:16 AM
Oranoco's Avatar
Oranoco
I ran a similar Piper profile cam in my old XR2i. With a whole load of time and money it just about eeked 130bhp. Tickover etc was fine.
Old May 31, 2015 | 02:57 AM
CrazyRx's Avatar
CrazyRx
CrazyRx
I',ve contacted the piper sales for a similar camshaft like this and they responded with this message:
The do camshaft for Pinto engine not the CVH. We do not make a cam for the CVH engine ... can't believe...
If i put this kent probably i need to change the springs and you should fit new followers with the camshaft. all the kit 370 phound...
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Steve Escos
Oct 1, 2015 06:57 AM
