Modine vs oil rad
Old May 30, 2015 | 09:26 AM
mattman1234's Avatar
mattman1234
Default Modine vs oil rad
Whats everyone's thoughts on replacing the modine with say a 16 row oil cooler,or running it in tandem.
Car will be used for general track days,and will be taking to spain again.Its about 350bhp.
I'm looking at a belts and braces approach,don't want it cooking if i'm thousands of miles away from home.
Cheers all
Matt
Old May 30, 2015 | 09:35 AM
Ridgey's Avatar
Ridgey
I replaced my modine with a thermostated sandwich plate plumbed into a oil cooler behind my front bumper. And seems to work well.
Never had temp issues.
Old May 30, 2015 | 10:58 AM
Mad_Mat's Avatar
Mad_Mat
New Owner
I,ve got myself a mocal 16 row oil cooler to fit on my 3dr.
But in my case one of the previous owners removed the modine and replaced with nothing . If its a fast road car the modine is probably sufficient imo but if track days etc then probably better off with 16/19 row mocal or similar cooler.
With the modine oil will probably get upto working temp from cold a bit quicker as it exchanges heat from the coolant into the oil.
My preferance is definitely a seperate cooler however as youre not putting that heat energy into your engine cooling system to deal with imo giving a bit more headroom on those hot summer days.
Old May 31, 2015 | 11:25 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
I replaced the Modine on my XR4x4 twin turbo with a 19 row Mocal cooler and thermostatic sandwich plate as the cooling system wasn't coping on hot days. Oil temperature is the same but the cooling system never gets too hot now.
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
