ford orion efi turbo
Hi I have a orion with a 1.6 efi in in I have just put an rs turbo engine in it with a ofab ecu and o have done some pin changes that I found off a forum but still won't start I have no spark could any one shed some light on this situation checked crank sensor and replaced all plugs
Not,all the looms need pin changes mate, it depends on what ECU the original engine was running.
Also, you have changed the MAP sensor etc to the turbo ones yer.
Ginger
Ginger
marky_g
Aug 15, 2015 10:43 AM
