head bolts rounded out
Old May 26, 2015 | 07:34 PM
bigdel's Avatar
bigdel
Default head bolts rounded out
Trying to take the head off the FRS engine, and the middle two head bolts have both rounded out.
Is drilling the only option?
Anyone know if someone in the Berkshire area does this on a mobile basis?
Old May 26, 2015 | 07:37 PM
studabear's Avatar
studabear
What fastener type are they, hex, torx?
Could you get a nut welded to them?
Old May 26, 2015 | 07:44 PM
bigdel's Avatar
bigdel
they're Torx. can't get a welder on to them, they're down a big hole in the head, needed about a 3" torx bit to get down to them. All the others came out ok, just the two between the cams are causing the headache
Old May 26, 2015 | 07:47 PM
studabear's Avatar
studabear
How many head bolts have you removed there are only 10
Old May 26, 2015 | 07:49 PM
pcbp97's Avatar
pcbp97
You could try drilling the centre of the bolt and using a suitably sized easy out in the hole, which should then unscrew the bolt. failing that drill the head off the bolt, remove the head then use a pipe wrench to remove the bolt from the block. hth
Old May 26, 2015 | 07:52 PM
jamie956's Avatar
jamie956
http://www.ebay.co.uk/itm/NEW-RELEAS...-/181460166138
Old May 26, 2015 | 07:55 PM
studabear's Avatar
studabear
The 2 between the cams don't hold the head on.
Look at this pic.
Old May 26, 2015 | 07:59 PM
Chopshop85's Avatar
Chopshop85
As said, they are plugged holes for sensors on other models. Looking at the zetec block im doing up at the minute someone had a good go at trying to remove them at some point
Old May 26, 2015 | 08:00 PM
pcbp97's Avatar
pcbp97
just reading your post again the bolts that hold the head down are only located under the cams 10 in total. are you talking about the ones in the valley where the spark plugs are? if so these are sealed in and are not head bolts.
Old May 26, 2015 | 08:01 PM
studabear's Avatar
studabear
The ones near spark plugs aint head bolts.
Old May 26, 2015 | 08:07 PM
bigdel's Avatar
bigdel
8 bolts removed, 2 bolts shagged
Old May 26, 2015 | 08:08 PM
bigdel's Avatar
bigdel
bugger me, you're right. didn't think about it like that. assumed they were just bolts. it's my lad who's doing it. will go and have a look for myself i think
cheers guys, mucho helpo!
Old May 26, 2015 | 08:18 PM
bigdel's Avatar
bigdel
Result, that's saved few quid I reckon -
10 bolts out, 2 non-bolts shagged
Old May 26, 2015 | 08:43 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
You can use a spline bit and hammer into the head and then undo
Old May 26, 2015 | 08:46 PM
gingerturbo
Also Bergen do male irwins for damaged hex/ torx heads
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
