bleeding water system mk5 zetec s
Old May 24, 2015 | 09:10 PM
rs_jim's Avatar
rs_jim
Default bleeding water system mk5 zetec s
Hi all need some help with trying to bleed the water system on mk5 fiesta zetec s
Many thanks for
Old May 24, 2015 | 09:40 PM
Adam-M's Avatar
Adam-M
When I do mines I just leave the expansion lid on, turn the engine on with the heathers on and rev the engine to about 2.5k. Then squeeze all the hoses regularly until they are hot. The two top ones where the heather control valve is are a pain to get bled because they are higher up that the expansion bottle the air gets trapped in them.
Then unscrew the lid carefully as its pressurised to let the pressure and hopefully the air bubbles out.
This has worked for me over the years mate
Old May 24, 2015 | 10:25 PM
rs_jim's Avatar
rs_jim
Been trying that way today run it up then undo the expansion lid let all pressure out but don't seem to clear it
Old Jun 23, 2015 | 01:29 PM
rs_jim's Avatar
rs_jim
any ideas people
thanks
Old Jun 23, 2015 | 02:51 PM
Adam-M's Avatar
Adam-M
Try unbolting the water bottle and lift it higher up than the hcv, problem with the setup is the hcv is the highest point in the water system and water sometimes gets trapped in it rather than escaping through the expansion bottle.
Take it your not getting any heat through the blowers?
Old Jun 23, 2015 | 03:49 PM
rs_jim's Avatar
rs_jim
Already tried that idea I replaced the hcv with a pattern part on a Saturday the heaters was working fine the car was fine for 2 - 3 weeks then noticed the temp gauge was past half way felt the rad hoses and Could feel air bubbles and hear them now replaced new water pump and thermostat but still gets pressurised done a test to see if headgasket gone but it's fine the fan cuts in and out just the temp gauge goes up then the heaters go cold and you can hear the air in pipes and header tank
Old Jun 23, 2015 | 04:22 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Thrash it up the road to high revs with heater on full. Usually forces the air out with the faster water flow.
Old Jun 23, 2015 | 04:35 PM
rs_jim's Avatar
rs_jim
Tried that several times stopped let pressure out but no luck
rex647
Mar 6, 2022 06:20 AM
Shaunc
Escort Range
Sep 22, 2015 06:38 PM
Chopshop85
Sep 18, 2015 06:13 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
ST-170
Sep 4, 2015 11:02 AM
