Cosworth fan not working with MSD loom?
Can anyone who has an MSD updated fan loom in the Cossie help me out?
The fan only works if I Earth the black bypass wire. I've tried a new fan switch but still not working.
It was fitted to the car when I bought it so not sure if it's fitted correctly but looks pretty simple so I'm assuming it is!
It's bugging me now
It's bugging me now
My fan switch was fooked on my cossie even though it was only a few years old. Take the plug of the fan switch then put a piece of wire in the plug and see if the fans come on.
Don't suppose you could tell me what connector it was I fitted the msd loom to mine a couple of months ago and went out tonight and the fans didn't cut in or work on the override havnt had time to look as I was out when I realised and it was dark when I got back
Cheers mate can't see how it could be wired poorly it's pretty idiot proof and too my time to run it down the inner wing nice the connectors for the fans looked a bit cheap and will clean up the Earth on the battery and try that
Is it an option the fans could have died or are they pretty reliable?
Well the fans are working with power directly from the battery so wil have to bring the car home and look further but can't see any obvious problems with it proper odd
muz
Aug 16, 2015 12:57 PM
Aug 14, 2015 07:29 AM
yawiejon
15
Aug 9, 2015 06:36 PM
