I have a problem with my escort rs turbo s2 90spec. My car didn't bring electric windows and central locking so I bought two doors that they had it.
I put everything on my doors and took the cables through the grommet into the car but the car haven't got electrical installation inside where connecting the plugs coming out of the doors.
Could you say me how to do a separate electric windows and central locking installation without the original conectors?
Thanks greetings.
Here a photo of my car without the dashboard, and near the place of the speakers the conectors
of the electrical window (white) and central locking (red)
buy the harness and it will make sense to you, I see you have switches on your door handles, and locking motors are in the doors,
right or left hand drive harness will work , your car has power feeds, don`t panic !!
Thanks for all, but i decided to do the electric instalation by myself.
All is runing now
I did it this way:
For central locking:
His termination plugs have three wires: red, white, yellow.
Red wire: Direct to positive
Yellow wire: Connect it to the yellow wires of the other two engines
White wire: Connect the white wires of the other two engines
(The latter two operate as a relay, motor polarity is reversed for them as you turn the key)
For the electric windows:
His termination plugs have 4 wires: black and yellow, green and yellow, blue and yellow, brown.
Brown wire: Direct ground
Black and yellow wire: Positive, here are two options:
If we want to work whenever you want, that is, without giving the contact, we put it directly to positive.
If we only work with the ignition, we put it to the 2nd connector bowler.
Green and yellow wire: We connect the green and yellow wire of other windows
Blue and yellow wire: We connect the blue and yellow wire of other windows
I recommend putting the cables to positive by an air fuse .. I put it one of 10A to the central locking and one of 20A to electric window.
