Puma radio interference when ignition on or engine running.
Old May 19, 2015 | 08:15 PM
gordyshreds's Avatar
gordyshreds
Default Puma radio interference when ignition on or engine running.
Ford Puma 1.6 2001
The original Ford 6000 CD player wouldn't tune 99% of the time and as they are known to go wrong I replaced it with a new Panasonic head unit and used an Autoleads ISO wiring adaptor harness.
Problem is this...
Turn key to position 1: Radio works faultless
Turn key to position 2 or when engine running: Radio tunes fine but has interference, almost like a rhythmic crackle every second or so.
What could be causing this? I've seen you can get an inline noises suppressor filter for the power wire. Is this worth doing?
I have tried routing the wires a bit better, away from the aerial lead etc but problem persists.
Please help as it's driving me nuts!!
Old May 24, 2015 | 10:20 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
They normally have a built in suppressor so you could try and locate where that is, I.e in the loom, alternator, etc
Old May 25, 2015 | 06:32 AM
STeve's Avatar
Super Moderator
very unusual to get this on modern cars as this used to plague us old farts on cars from the 70s'80s, could be down to a missing earthing strap or maybe the coil pack,ht lead
JoeyBoyden
Jan 4, 2024 02:36 PM
Ben26
Sep 1, 2015 06:29 AM
Sheepdisease
Aug 30, 2015 09:11 PM
Ben26
Aug 27, 2015 08:56 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
