Engine Mount Stupid Question
Old May 19, 2015 | 09:54 AM
haz87's Avatar
haz87
Default Engine Mount Stupid Question
Having a complete mind blank....
You can get 86-88 and 88-90 engine mounts.
Presumably these are based on the chassis rather than the engine (as iirc all cvh blocks are drilled the same for the mount)??
Also anyone using a Vibratechnics engine mount? Been using their gbox mounts for years and rate them but don't know if the engine mount is going to be overkill or not (mounts failed so need to replace either way).
Cheers,
Harry
Old May 19, 2015 | 05:50 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Some mounts have the hole for the wing bolt higher/lower than others, the RST is lower so the mount is longer, I have a pic somewhere I'll see if I can dig it out mate.
Oh and you'll get a nice vibration at idle and low rpm with the VT mount (if you don't already).
borboyous
Aug 22, 2015 11:17 AM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
lockie
Jul 31, 2015 10:03 PM
