T34 water feed/return aeroquip?
Has anyone replaced the water pipes and replaced with aeroquip lines? Can this be done to replace tired old water pipes that might split? If so what size AN fittment is to be used?
Hi i have changed mine on a T34 on a 2wd sapp with the Torques fittings. The thread is M18 x 1.5 from memory so i bought 2 M18 x 1.5 to AN-6 fittings to go into the core, a 90 AN-6 to go between turbo & the head & a 45 AN-6 for the other side, 1 metre of braided stainless pipe & 2x anodised hose finishers for the others ends. Hope this helps.
I changed the water pipes on my gt30 to torques Teflon aero quip stuff. I used there banjo bolts. Also used the foil looking high temp heat sock stuff over the pipe close to the turbo as well as it dose get hot down there.
Thanks for the info do you both have any pictures of your set up pls?
Ive bought a bulk load of AN-6 fittings and piping too to do my fuel supply so will have some left over so was thinking about replacing the water pipes.It will look alot better and be alot safer too i would of though.
The pictures I have don't show the fittings and I've not got that set up any more as I'm building a new engine! Mine went from stat housing to turbo then from turbo to turbo cooler rad. My set up was on a cosworth. I'd use Teflon hose if I was you as it with stands higher temp and I'd use the heat sock for hoses as well as it gets hot around the turbo
as above..m18x1.5 adapter fits in the turbo (same fitting you would use in the big end of a 044 fuel pump) and what ever fitting you find you need from there
http://www.ebay.co.uk/itm/6-AN6-06-M...item2309ce94bd
or if room is a issue these
http://www.ebay.co.uk/itm/6-AN6-06-1...item27d30c00ef
http://www.ebay.co.uk/itm/M18-x-1-5m...item27d30c04de
Thanks for the info guys will get 2x M18x1.5 adaptors from the bay.
With reference the ends that go into the thermostat and header tank how do i fit male pieces do i get them drill and taped or do i need them welded in situ?
Mark RS
Oct 12, 2015 06:01 AM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
