Tidying the loom up in a saph
Old May 11, 2015 | 08:48 PM
dissmalrs's Avatar
dissmalrs
Default Tidying the loom up in a saph
I'm in the prosess of rebuilding my saph and I would like to hide the wireing loom under the bonnet to make it a bit neater.
Has anyone done this or have any ideas how I can refit my loom
It's looking s bit of a mess now.
Old May 11, 2015 | 10:07 PM
anglia105e hinson's Avatar
anglia105e hinson
Yes I have done this in my 3 door .
I tucked 90% of it underneath the chassis rails instead of on top .
Old May 11, 2015 | 10:09 PM
anglia105e hinson
Old May 11, 2015 | 10:13 PM
anglia105e hinson
I run all the wires that are infront of the bulkhead panel behind it .
And re- wired and covered with new plugs on the engine loom
I also run it all underneath the inlet instead on top .
Looks so much neater
Old May 11, 2015 | 10:46 PM
cossiestu's Avatar
cossiestu
That looks much better!! Did you have to lengthen it to get it under the chassis rail?
Was going to rewire mine to run under the inlet, but didn't trust my soldering!!
Old May 12, 2015 | 08:37 AM
anglia105e hinson
There was only a couple I had to extend the coil , and washer I think.
I started by underneath the master cylinder and fed it under the chassis rail and continued all the way round to the other side pining it along the way.
I also moved the battery to the boot.
So all the power wires dive under the black bulkhead panel into a bmw power distribution block.
Old May 12, 2015 | 09:26 AM
cossiestu's Avatar
cossiestu
Looks much neater!!
Old May 13, 2015 | 03:16 PM
James @ M Developments.'s Avatar
My engine looms tidy the bay up no end, I made them so they sit out of the way keeping most of it hidden.
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
muz
Sep 30, 2015 08:29 AM
Russ Payne
Sep 25, 2015 08:29 PM
