Fitting Focus RS brembo's on Escort Cosworth
Old May 10, 2015 | 09:33 PM
steve st220's Avatar
steve st220
"SNIFF MY DIFF"
Default Fitting Focus RS brembo's on Escort Cosworth
Anyone know if the Focus RS brembo callipers can be fitted to an Escort Cosworth,
can you use the Focus RS discs and who makes the brackets to fit the callipers ?
Old May 10, 2015 | 10:26 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
Can be done, i had escos brakes on an xr2, then fitted frs brembo brakes next.
As for brackets i have no idea, i made my own from 10mm mild steel.
Old May 11, 2015 | 06:47 AM
Marc sierra's Avatar
Marc sierra
The discs won't fit, they will foul the steering ball joint. The calipers might fit, depending on what wheels you are using.
Old May 11, 2015 | 07:55 AM
Fezman1's Avatar
Fezman1
Discs wont fit as they are the wrong offset if you like.- they sit the disc too far back on the hub. The discs are more suited to 2wd.
I wouldnt bother with the FRS Brembos on a cosworth, there nothing special tbh. Id look at the likes of Subaru STI or Evo brembos or something else.
Old ford
Jul 31, 2015 06:50 AM
