Smoking Cosworth
Old May 8, 2015 | 07:45 PM
stevenr's Avatar
stevenr
Default Smoking Cosworth
I noticed last night my Sapphire has started to smoke a bit on overrun,taking it out today and it seems ok at start up but again quite a bit of smoke on overrun and giving it a rev from idle once i stopped it gave a few puffs and seemed to clear at normal driving speeds.
A bit of googling suggests valve guides maybe stem seals or the turbo could be on the way.
Being new to the Cosworth engine what's best to start with?
It's meant to be on a stand next weekend at the McRae rally challenge so I could do with it being something simple I hope.Being an old Ford though I doubt it haha
Old May 8, 2015 | 08:35 PM
Caddyshack's Avatar
Caddyshack
Check what oil it is running, then get a cylinder leak down test and compression test after you have used it in anger on decent fuel. After that it could be rebuild etc but use it well first.
Old May 8, 2015 | 08:51 PM
costina's Avatar
costina
Live long and prosper!!
Black or blue?
Old May 8, 2015 | 08:57 PM
stevenr's Avatar
stevenr
More blue colour I'd say which suggests it's being burnt doesn't it?
Might just see if I can get someone to have a look.Wife will go nuts spending more money on it just now
Old May 8, 2015 | 09:03 PM
costina's Avatar
costina
No smoke on start is a good sign so rules out stem seals and guides.
Overrun could suggest turbo. Remove turbo to cooler pipe and check for oil.
This oil finds its way into intake manifold and on overrun which creates vacuum sucks oil into combustion.
What breather system are you using and is it clean?
Old May 8, 2015 | 09:11 PM
stevenr's Avatar
stevenr
It's a bailey breather system.Not had a look to see if it's clean or not but that would be easy enough after work tomorrow
Old May 8, 2015 | 11:20 PM
James Porter's Avatar
James Porter
I think I'd be more worried if my Cossie didn't smoke
Old May 9, 2015 | 01:28 PM
stevenr's Avatar
stevenr
I spoke to someone about it today and he pretty much said the same thing.
What's coming out of this thing though is a bit more than just the usual wee puff here and there.
Going to have a look at the pipework and breather system and try that today before making the call for surgery on monday
Old May 9, 2015 | 01:57 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
can you even get a cossie that don't smoke and stink of fuel and oil
Old May 9, 2015 | 03:16 PM
Sierrasideways's Avatar
Sierrasideways
Mine smoked on overrun too recently and the turbo was gone. No smoke on startup either. I'd check your turbo for play and the return pipe to intercooler for oil, as said above.
Philip.
Old May 9, 2015 | 05:48 PM
stevenr's Avatar
stevenr
There's no oil in the turbo to cooler pipe at all,slight play in the turbo though.
Breather system cleaned out too although it wasn't too bad but took it out a run and still smoking like a fucker after a good booting.Still pulls very well though
Old May 9, 2015 | 06:26 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
smoke is fine, especially a bit of black on a cossie but i have never been a fan of blue lol.
Old May 9, 2015 | 06:48 PM
stevenr's Avatar
stevenr
If it was black i wouldn't really care about it but this blue stuff worries me a bit,well not so much worries me but it scares the shit out of my wallet
Old May 9, 2015 | 07:29 PM
Ebonycossie4x4
agreed, I've been there probably 5 times over the years and always seems to be the dearest possible thing, i think 4 of them have been a rebuild and one turbo.
Old May 10, 2015 | 01:07 PM
Cossiemainful's Avatar
Cossiemainful
Coloured smoke is never normal (if the engine is on operating temp!). When ppl agree and say "it's an old car, so it's normal" so they think it's not worth it to fix such an old car IMO.
Blue smoke is a sign of unburnt fuel or burnt oil. You can fix this problem, never mind how old the car is, it is never normal, at most tolerable
Old May 11, 2015 | 10:09 PM
daz1968's Avatar
daz1968
Have a leak down test as I had similar on my 3 door it smoked on over run and cleared under boost, I tried all the usual, and it ended up being a bit of everything but biggest concern was bore wear. Ended up with full rebuild and it hasn't really used any oil since. Expensive but worth it if keeping car. Once I knew what it was I just started collecting main parts a bit at a time then pulled engine out over winter and got it done.
Old May 12, 2015 | 08:17 AM
It's Czech Mate's Avatar
It's Czech Mate
I'd worry if it was balck as that would be excess fuel....and likely borewash
Old May 12, 2015 | 08:54 AM
Cossy Mike's Avatar
Cossy Mike
Mine was crystal clear after new turbo and engine rebuild.
Now after mapping I get a little blue on over run, I blame the std breather, I'm running 365bhp with 27psi boost.
I think the pressure in the crank is forcing the oil past the rings
Old May 12, 2015 | 11:28 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
Check the exhaust side of the turbo for oil. Sounds like seals on way out.
Old May 12, 2015 | 04:42 PM
costina's Avatar
costina
std breather sucks the shit from the kidney box into the plenum. When engine is on vacuum/overrun.
Old May 12, 2015 | 06:00 PM
stevenr's Avatar
stevenr
It's going in to get checked out next week.Hoping it's nothing too serious but needs fixed anyway so I'll be letting them deal with it.
Just noticed something last night though,the little plastic stopper on top of my dipstick is fucked and moving up and down so i'm not getting a proper reading.Too much oil wouldn't be helping would it?
Old May 13, 2015 | 06:47 AM
Cossiemainful
Black smoke is an unclean combustion (blocked air filter, faulty O2 sensor etc.)
The engine is working correctly if the smoke is almost colourless on operating temp.
rsturbo27
Sep 1, 2015 09:54 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Aug 14, 2015 07:29 AM
Adam-M
22
Aug 10, 2015 10:46 AM
