Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
ST170 Speedometer
Old May 5, 2015 | 05:54 PM
avfcboy1974's Avatar
avfcboy1974
Default ST170 Speedometer
Hi all sorry for sounding a bit dim but, recently when changing my speedometer on my st170 I noticed behind there was a wiring loom with a grey connector plug. This had been disconnected probably by a former owner. What is this lead for and do I need to connect as the clocks seem to work fine without it ?
Old May 6, 2015 | 08:50 AM
mcst's Avatar
mcst
Does the engine light come on when you start then go out after? If not, could be that the light was on and to hide it it's been disconnected?
Old May 6, 2015 | 09:19 AM
STeve's Avatar
Super Moderator
normally its for the illumination of the oil gauges, unless somebody has bypassed it due to a fault
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Andypandy260
Sep 23, 2015 10:28 PM
pie-face
Sep 15, 2015 10:43 AM
