FDS/WDS diagnostic systems question
Old Apr 3, 2005 | 02:28 PM
Azrael's Avatar
Azrael
Default FDS/WDS diagnostic systems question
From what I found out mainly here on forums EEC IV Escort Cossie schould connect to FDS2000 diagostic equipment Ford dealerships have. Friend of mine took it there, they even found out the 3 pin diagostic socket for which they have a plug in their system. They found Escort Cosworth on the diagnostic program but they wouldn't comunicate. Are there any more things I schould know? Some info out of engine ECU would be usefull for maitenance and setup.
Old Apr 4, 2005 | 10:47 PM
Azrael's Avatar
Azrael
Noone?
Old Apr 5, 2005 | 03:35 PM
sailorbob's Avatar
sailorbob
I'm just guessing here but isn't the 3 pin plug just the STI connector? I thought that the FDS2000 connected to a trapezoidal shaped plug that is a combined STI/DLC plug. See http://www.autoxray.com/products.aspx?sub=cables&id=9 for what I mean.
Old Apr 5, 2005 | 09:28 PM
Azrael's Avatar
Azrael
Originally Posted by sailorbob
I'm just guessing here but isn't the 3 pin plug just the STI connector? I thought that the FDS2000 connected to a trapezoidal shaped plug that is a combined STI/DCL plug. See http://www.autoxray.com/products.aspx?sub=cables&id=9 for what I mean.
Thereis trapezoidal plug there. If they could plug it in they probably found the right one but no communication. Can anybody clarify to which one they schould connect and what schould they do with the diagnostic eqipment for it to work?
Old Apr 6, 2005 | 09:11 AM
sailorbob's Avatar
sailorbob
Spot the earlier typo it should be DLC not DCL.
I believe the 3 pin plug has the following connections, STO pin 17 of ecu, STI pin 48 of ecu, third pin to ground.
I've no experience of the diagnostic equipment so I can't help, sorry.
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
