2002 Transit tdci
Old Apr 29, 2015 | 10:14 PM
slammedorion's Avatar
slammedorion
Default 2002 Transit tdci
Mate's transit cut out the other week...
Ended up towing it back
We've put in on a snap on reader and it says
Is it new pump time? Or something that can be repaired?
Old May 1, 2015 | 07:58 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Normally new pump, we get them a lot at work, there's a fuel metering valve on the back of a lot of these pumps that can me replaced depending on model, that's normally what controls the flow of diesel, have you checked the pressure sensor as that can also have an effect if its reading the wrong pressure on the rail
Old May 1, 2015 | 09:31 PM
jamie's's Avatar
jamie's
You sure its a tdci if its a 02?
Old May 3, 2015 | 05:01 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Deffo pump time. As said though check its deffo TDCI seems a little early.
Pumps can be repaired but easier just replacing with a second hand unit. Make sure you get the proper timing kit! Easily done in situ without removing chain.
Old May 7, 2015 | 09:46 PM
slammedorion
2nd hand pump off eBay, £140... ( bit of a gamble )
A mate's fitted it, coded it etc... It's running spot on again...
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
The Enigma
Sep 29, 2015 10:31 AM
deathrider666
Sep 28, 2015 06:12 PM
