lambda sensor fitment
Old Apr 29, 2015 | 09:05 PM
RIB1122's Avatar
RIB1122
Default lambda sensor fitment
I'm about to fit a lambda sensor boss to my cossy. is there a proper place to fit it?
how far on the down pipe?
Old Apr 29, 2015 | 09:14 PM
studabear's Avatar
studabear
Is it for a wideband? Normally in the instructions it will tell you a minimum distance from the manifold/head or turbo.
Old Apr 29, 2015 | 09:24 PM
RIB1122's Avatar
RIB1122
its for this as
http://shop.motorsport-developments....bung-319-p.asp
I'm getting closed loop upgrade
Old May 1, 2015 | 07:32 PM
RIB1122's Avatar
RIB1122
anyone?
Old May 1, 2015 | 10:56 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Anywhere on the downpipe should be fine. Make sure you mount it so that the sensor points at least slightly downwards to the tip. They don't like sitting in condensed exhaust gasses.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
