RS500 ABS Cluster Lights
I have a RS500 cluster I'm going to use. I wish to know the wiring arrangement for the ABS warning light in the middle, the ABS harness I'm using is from a Sapphire which uses the small bulb socket that normally would twist lock in rear of Sapphire cluster.
Does anyone know the color of wire any connector type for this..
You talking about the light not working or the ABS system?
I installed the entire system, brake master, ecu, harness, sensors, lower arms and front hubs with correct tone wheels from a Sapphire 2wd Cosworth, into a Merkur XR4Ti that didn't have ABS. The system is working, hit a wet spot under hard braking and felt the front circuit being activated. Just would like to wire up the warning lamp properly. Got a Sapphire cluster that I could interchange cluster panels to use its bulb socket but would like to connect the one above in pic to warn me. If I can find out the proper circuit for the light I'm good.
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
The Enigma
Sep 12, 2015 10:12 PM
