2003 1.6 Focus Smoking and Oil in Cylinders
Old Apr 28, 2015 | 08:06 PM
JR90337's Avatar
JR90337
Default 2003 1.6 Focus Smoking and Oil in Cylinders
Hi all, new here: unfortunately it's a problem that's brought me here. I recently took a chance on a 2003 Focus that had sat for a while. It drives perfectly - has just over 100k on the clock but it's incredibly tight, starts easily and pulls well through every gear.
Took it for an MOT and got a call to say they can't test it because it's pumping out smoke. Got it home and pulled the plugs and they're all oily. No mayo in the oil - no oil slick floating on the coolant in the expansion tank either.
Thinking it's probably piston rings or stem seals, though I'd expect the engine to run badly if it was rings - and for only one or two, not all cylinders to be effected.
Really just wondering if there's anything simple it could be or if there's any known faults with these engines that could point to a likely cause. Sorry if it's a bit wordy, just wanted to makes sure I've covered everything! Cheers.
Old Apr 28, 2015 | 08:24 PM
3i Jim's Avatar
3i Jim
10 Year Member
Check the breather pipes aren't blocked.
RUBY123
Oct 22, 2023 12:04 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
