L6 - L8 and 4x4 loom
Old Apr 24, 2015 | 08:12 AM
KW-rscos's Avatar
KW-rscos
Default L6 - L8 and 4x4 loom
As above I have recently bought a 2wd Saph, but I have an L8 Ecu at home and also a brand new MSD 4x4 loom (all intended for my 4x4 saph before deciding to go a different route). So my question is, can I simply remove the old loom and ecu, put the new loom and ECU in, swap the TPS over from the 4x4 and then put a lambda boss in the down pipe?
Also what do I di about the 4x4 loom having a knock sensor?
Regards, Kieren.
Old Apr 24, 2015 | 04:45 PM
jamie's's Avatar
jamie's
You dont need to run a knock sensor, if you want you can connect 1 up but it'll run as normal without it, if the chip is set up for closed loop then you can fit 1 into the downpipe and use the existing wiring on the 4x4 loom, no need to change the wiring at the tps if its a 4x4 loom and l8, just change the tps to a pf09
Old Apr 24, 2015 | 06:05 PM
KW-rscos's Avatar
KW-rscos
Is there anywhere on the 205 block that I can connect a knock sensor straight up to? I have a pf09 so I will use that.
Old Apr 25, 2015 | 07:23 AM
cozzy jeff's Avatar
cozzy jeff
Knock sensor just screws in the same place as on 200 block
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
muz
Sep 30, 2015 08:29 AM
