300 rear disc conversion help
Old Apr 20, 2015 | 05:31 PM
Tinshaw's Avatar
Tinshaw
Default 300 rear disc conversion help
Hi all has anyone fitted reyland rear 300 disc conversion? Saph 4x4 cos
As I'm trying to fit mine up but the dust shield is in the way,
Does this have to be removed?? Or am I doing summit wrong? I'd phone Martin but it's out of work hrs!! any help would b grate.
Cheers Lee
Old Apr 20, 2015 | 06:18 PM
Cossy Mike's Avatar
Cossy Mike
Cheers Lee
Think you have to trim the 2wd shields and make sure the brackets are correct side so your handbrake cable is long enough
Old Apr 20, 2015 | 06:54 PM
Caddyshack's Avatar
Caddyshack
I think you might as well throw away the dust shields as they will be smaller than the discs anyway.
Old Apr 20, 2015 | 07:33 PM
Tinshaw's Avatar
Tinshaw
I new that was going to b the answer
Cheers mate.
Old Apr 21, 2015 | 06:11 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Bin off the dirt shields
Old Apr 21, 2015 | 06:28 PM
c20tbo's Avatar
c20tbo
Is that the same as an Escos Martin?
Old Apr 21, 2015 | 06:34 PM
Caddyshack's Avatar
Caddyshack
Unless the escos are offset n larger then yes
You will not find a race car with dirt shields. Without the air cools more, it was the first thing we did on my track day 911 on the advice of a lemans and Porsche experienced engineer
Old Apr 21, 2015 | 07:07 PM
Martin-Hadland
Yes, they're not needed anyway. Whoops.. Also forgot to reply to your email
Old Apr 22, 2015 | 08:13 PM
Caddyshack's Avatar
Caddyshack
I haven't had a reply to my email either....I git my brake parts with a note from you to say my brake pipes are to follow but not had them. Toby (4x4 cossie fronts)
Old Apr 25, 2015 | 04:25 PM
Martin-Hadland
Sorry about that, I will contact the hose people on Monday. I was out of them and asked them to post directly.
Old Apr 25, 2015 | 05:26 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Great kit I have one on mine. I binned my shields as there not needed
Old Apr 30, 2015 | 09:18 PM
AndyPen's Avatar
AndyPen
I trimmed mine back a fair bit and it worked fine
yatta
May 21, 2016 10:31 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
S3an
13
Sep 13, 2015 10:01 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
cossirob
Sep 3, 2015 09:17 PM
