extensive list of WRC and RS2000 Maxi/Kit car part, new and used.
more pictures here- http://s210.photobucket.com/user/mat...s%20for%20sale
• Inner cv joint spacers 45mm x4, 35mm x3, 50mm x2
• Zf power steering engine mount and pump brackets -1x set
• Upright bearing caps 9095757 x5 pairs 1xblue 1xblackk 1xsilver, some brand new in wrapping.
• Cv joint inner spacers, thin. various thicknesses.
• Escort maxi long arb drop rods x3 (top mounted ARB maxi style)
• Wheel spacers various thickness
• Red anodised steering blocks 3 x pairs.
• Steering block top supports x9 pairs.
• X tract rear bottom gear box mount x5 with no bushes
• X tract small length gear linkage bar x4
• X tract long length gear linkage bar x2
• Water pump pulley, small, x4 new, x1 used
• Header tank bracket x1
• Left hand drive accelerator pedal mount x2
• Water pump for water cooled calipers with bracket x3
• Bracket for above pump x4
• ARB mounting brackets x1
• Steering column bearing mounts x3
• Stainless battery mounts x2 pairs, x1 loose
• Brake caliper mounting spacers x3 pairs
• Power steering bracket spacers x4
• AP master cylinder 0.7 (x5), 7/8 (x3) 5/8 (x1), x1 brand new 0.7
• Small blue handbrake lug x2
• Sb175 amp connection red x1
• Brand new Bulk head steering column boot mounts 181815077 x5
• WRC oil cooler blocks x4
• Master switch mounting aluminium plate x1
• Alcon floating bells x2 3726/280x28.0mm
• Rear hub spacers 25mm x5, 15mm x2,10mm x2
• Front top mounts x1 pair with bearings
• Alternator pulleys x11
• Lamp pod latches x11
• X tract gearbox bulk head cross linkage piece x2 black x1 blue
• X tract gear stick mounting plate x2
• Power steering pump pulley x3new
• Red anodised ecu mounting front facias x5
• Rs badge x1
• Rs 2000 badge x1
• 16 v badge x2
• Rear lights x1set
• Ford left hand side inner wing mirror blanking plates x2
• Red anodised bulk head heater matrix hose connectors x2
• X tract gear leaver knob x1
• Alternator mouthing brackets x6. 2 are different.
• Rear disc bell x1
• Rear disks brand new 1xpair
• Custom light weight aluminium bonnet hinges x1 pair and x1 on its own
• Kit car sump x1
• Front disks with bells for gravel x1 set
• Brake bell for above x 1
• Front calliper mounting bracket x2 pairs plus one off specials contact for more info.
• Front brake calliper water coolers x4
• Crank shaft pulley vibration dampers x2
• Front sump guard mounting brackets x8. x3 are slightly different.
• Front TCA's 1 x pair
• Brake disk bells x4 (9095421), for smaller disc.
• Mocal oil to water coolers, small x2
• Light weight rear billet aluminium hub carriers complete with flanges, bearings and splines x 1 pair (brand new unused)
• Tyre warmers 110v x4
• Window wiper mechanism x1 linkage arm missing
• Anti roll bars various contact x7
• Sump guard x1 Extra long sump guard to be used on rough surface has more coverage of underneath of car
• Escort maxi single head light covers 4xleft 1xright
• Standard sump x1
• Front crossmember silver very good condition x1
• Kit car rear beam no triangulation arms brand new unused unpainted wrapped x1
• Right hand drive maxi single headlamp mounting brackets x3 brand new unused 181799020
• Bag tank aluminium facia plates brand new x2
• Side exit exhaust manifold back x1
• Fuel pump and filter set up x1
• Gravel spec rear beam, just needs hubs.
• GPRA wheel inserts
• Bilstien top caps
• Bilstien jumbo adjusters x2 (new)
• Bilstien top bearing mounts (9093257) x2
• Spring seats x4
• Bilstien red anodised top mount x1
• TCA/Comp strut left/right hand adjusters x2
• TCA/Hub bolts x5
• Spacer for above x6
• ARB drop rods x3
• Small front ARB drop rod x 4
• XTRAC gear lever bottom bolt/pin x3
• Rear beam bearing adjusters x6 and 1 bearing
• 9092450 x many
• Bag tank alloy mounting plate
• AP master cylinder push rods x9
• Heavy duty steering arms x2
• Senders x3
• ZF drive pulley x1
• Pressure gauge x1
• TPS x2
• Pedal box adjuster x1
• Bonnet pins, various
• Steering arm block bushes x (many) 181815027
• Steering rack inserts/mounts x (many) red and blue anodised.
• Steering track rod ends x2
• Bearings for above x (many)
• TCA bushes x(many)
• Compression strut bushes x(many)
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
