mk6 escort 1.4, both front electric windows don't work???
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Hi all. Well I have a new daliy in the shape of a mk6 1.4 4 Dr escort. I really love it and is so much nicer to drive than my old panda. But the biggest prob is both the front electric windows don't work. They don't even attempt to go up or down. I've checked the fuse, but I'm a old skool guy and am not to good with electrical stuff. So any help is much appreciated?
they suffer with wiring looms going green and disintegrating usually under the drivers feet the loom is separate plugged into the back of the fuse box if the drivers side don't work the passenger side wont
Yeah that's the case both sides don't work. If what you sait is what's wrong where should I start to look?
first place I would look is the switch tbh as very common area to fail, then start digging deeper like plugs/relays/fuses and worst case motors etc
Agree with you , quite often people think of the worst case scenario first instead of starting with the simple things. For the small cost of new switches that would be number one.
My 2wd Saff had a problem with the drivers front electric window not working, one new switch and as good as new again.
Finally got round to looking at my Windows i've got power to the switches but when I tested it only one of the two switches worked but still no Windows open????
I'm pretty certain, if one switch stops working, it'll affect both windows.
Right ok then mate, I tested it also with a single switch off a mk5 so that would be why it wouldn't work with that too. I'll pop to ford tomorrow and see if thay got one.
