Fuel pressure regulator
Hi,
Has anyone here tried a fuel pressure regulator from another car on a Sierra Cosworth?
I would imagine that once a regulator blows off at 3.5 bar it would work, providing it would physically fit!
Cheers,
Dave
Cheers,
Dave
Thanks,
Dave
Its a rising rate type regulator,
The fuel pressure rises at the same rate as the boost pressure
The vacuum pipe is what conects it to the inlet to match thhe boost pressure
If you swap it over then you must swap it with another 1:1 rising rate pressure regulator
SMILER258
Sep 28, 2015 09:04 AM
Dubs44
Sep 19, 2015 06:31 AM
