car problems, no one seems to know the answer to
Old Apr 13, 2015 | 02:05 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Default car problems, no one seems to know the answer to
got myself a 1.4 zetec fiesta about 6 months ago and with full history and all that stuff it's been absolutely mint, other than a small problem that just won't quit
when it's cold, below 60 degrees water temp, the idle can be as high as 1400rpm, which is a shit because the gearbox doesn't want to get into 1st or reverse and now it's crashing in the gears even when it's warm
this morning i took the top of the car apart to change the temp sender and found that the old one was fubar, the grey plastic bit was spinning in the copper bit
new part installed there was also an issue with the plastic inlet pipe which is split as you can see
but it's also breathing real heavy, just look at the state of the breather hose filter
but the air filter is spotless as is the rest of the engine bay, even the caps are clean (until i put my oily hands on one of them and it's now dirty yellow )
with the air system off, i started it up and the same, 1400 rpm, but with the pipes now off i poked my finger into the butterfly flap and it was covered in oil
so, any other ideas?
or do i just leave it as it is now?
Old Apr 13, 2015 | 07:01 PM
tones61's Avatar
tones61
air leak somewhere on inlet or pipes,
ie a split pipe/vacc/breather hose,
Old Apr 13, 2015 | 07:51 PM
3i Jim's Avatar
3i Jim
10 Year Member
Idle speed control unit?
Old Apr 13, 2015 | 08:16 PM
frsjon's Avatar
frsjon
i expect theres a breather pipe that goes to the air box/inlet hose which will cause your oil in the throttle body.. maybe worth spraying some carb cleaner in the TB, the oil maybe making it stick/not close properly?
Old Apr 13, 2015 | 09:02 PM
dojj's Avatar
dojj
but why would it then suddenly be "fixed" when the temp reaches 60 degrees?
i'm going to stick some carb cleaner in the next time i've got a day off and also change the pipe to eliminate that problem
one thing i did discover though is that when pressing the butterfly flap there was a "clonk" and if there was some play somewhere in the system, but it's all new fangled stuff so i'm not sure if it's related or not
Old Apr 13, 2015 | 09:19 PM
Harryh24's Avatar
Harryh24
the throttle body bloody expensive to to buy but seems few with similar problems
Old Apr 13, 2015 | 10:28 PM
chris cdti's Avatar
chris cdti
From memory the idle speed is controlled by the throttle body unlike the earlier Zetec SE that had a separate valve on the inlet manifold. It may be a cold start setting that keeps the idle slightly higher in the ecu.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
A.t.p
Aug 15, 2015 11:37 AM
