Diesel Fuel Filter - Installing precautions
Old Apr 12, 2015 | 05:02 AM
jayaprakash.panoli's Avatar
jayaprakash.panoli
Default Diesel Fuel Filter - Installing precautions
Dear Sir,
I own Ford Ikon Duratorq 1.4 TDCI 2010 model.
I am 72 years old and am maintaining the car by myself.
Recently I changed the Oil Filter, Air filter, Coolant and cleaned the MAF.
The car now exhibit excellent drive characteristic and very pleasant to drive.
Now I am planning to change the Fuel Filter also. But I heard air block may create problem if you are not careful. Please let me know the details of Assembly and technical precautions to be taken. I tried in the net but looks like it is protected item.
I am attaching the photo of the items insitu original and the new one I purchased (After market).
New Diesel Fuel Fliter Carton
Fuel Filter Diesel Side View
Fuel Filter Diesel Top View
Original in the car.
Old Apr 14, 2015 | 12:43 PM
Sp3no's Avatar
Sp3no
Have a can of clean diesel to hand, you will need to fill the new filter to the top with diesel once installed, the fuel lines will have air in them so if the engine does not have a hand priming pump you will need to get one to force the last remaining air from the filter. I had to do this on my Focus with a similar fuel pump, took me about 3 hours to get it started. I was only able to get it running once I got hold of the pump
Old Apr 14, 2015 | 03:14 PM
jayaprakash.panoli
Default Thank you,
Thank you,
Luckily my car has primer pre installed.
What my observations with the new filter are:
Sensor and heater connections are not pre installed hence I have to dismantle these items from the Original and install it on the new one.
Here I want to know what pre-caution one has to take???
Thanks in advance
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
155lee
Oct 27, 2015 04:55 AM
fordfiestamk3
Sep 11, 2015 12:52 PM
Bighandsuk
Sep 2, 2015 05:23 PM
