Steering rack leaking
Old Apr 10, 2015 | 08:58 AM
SGP's Avatar
SGP
10 Year Member
Default Steering rack leaking
Found out my cars steering rack and power steering was leaking fluid .
Car is at the spray shop and I can smell burn engine oil .
Anyone had this issues before
Old Apr 10, 2015 | 12:32 PM
Toe Knee's Avatar
Toe Knee
Can you see where its leaking from?! If it's the original rack/pipes etc they're a good 20+ years old!! Common is the rubber swirly pipe off of the pot as they crack but you can get silicon replacements now. If from the rack could be a seal or o ring gone etc
Old Apr 10, 2015 | 12:57 PM
SGP's Avatar
SGP
10 Year Member
Hi,
Do you know where I can get them ? The silicon replacements ?
Old Apr 10, 2015 | 01:58 PM
Toe Knee's Avatar
Toe Knee
Most cossie bit suppliers do them but I got mine off eBay
Old Apr 11, 2015 | 11:04 AM
SGP's Avatar
SGP
10 Year Member
Share the link 😄
Old Apr 13, 2015 | 01:14 PM
SGP's Avatar
SGP
10 Year Member
Old Apr 13, 2015 | 02:24 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Find out where the leak is coming from first, pump, rack, pipes, unions
The pipe unions tend to leak where they are crimp fitted from rubber to metal or the rack seals inside leak and then the fluid fills the bellows on the rack ends leading to a much bigger leak all of a sudden
Don't let the fluid get into the alternator either as it will kill it
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Fudgey
21
Sep 30, 2015 06:19 PM
IainRS1700T
Sep 25, 2015 06:44 AM
