Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Rattle under load - Zetec SE
Old Apr 9, 2015 | 08:38 PM
Prickly_buzz's Avatar
Prickly_buzz
Default Rattle under load - Zetec SE
Hope I can get some ideas/help on here!
I have a '03 1.6 focus zetec manual.
When I put the engine under load (usually after changing gear or just pulling away) I get a fairly loud clatter from the engine, sounds like it could be pinking.
I really don't know what could be causing this.
I have changed the cambelt and the timing is spot on (checked this recently).
The car does also feel underpowered compared to other 1.6 zetecs, I know they arnt powerful but it definitely isn't what it should be.
Any help would be appreciated!
Old Apr 9, 2015 | 08:47 PM
RichieST's Avatar
RichieST
Maybe a low oil pressure problem?
Old Apr 9, 2015 | 09:42 PM
Prickly_buzz
Maybe but it does seem like a pinking noise if you know what I mean.
I get no oil pressure lights and oil usage is normal.
Old Apr 10, 2015 | 10:36 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Could be the tensioner?
Old Apr 10, 2015 | 07:51 PM
Prickly_buzz
It has a new tensioner on it and it was apparent before changin the belt.
Old Apr 12, 2015 | 02:48 PM
Prickly_buzz
Just realised this is in the wrong section....
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
tankybaby66
Feb 6, 2016 02:24 PM
