Sapphire main beam issue
Old Apr 8, 2015 | 11:00 AM
P4ULT's Avatar
P4ULT
Default Sapphire main beam issue
Hi all
I have a problem with my head lights. I have no main beam, I have checked the earths, they are ok and the relay is clicking away.
Any ideas?
Paul
Old Apr 8, 2015 | 11:04 AM
Is there any lives going to the main beam bulbs.
Old Apr 8, 2015 | 11:35 AM
P4ULT's Avatar
P4ULT
Any idea on the voltage required?
Old Apr 8, 2015 | 12:05 PM
martysmartie's Avatar
martysmartie
12V.
Martin
Old Apr 8, 2015 | 12:19 PM
P4ULT's Avatar
P4ULT
Should I be checking that on the wire that goes to the main beam bulb, or the harness to the headlamp. If I'm getting no power where do I go from there?
Old Apr 8, 2015 | 01:17 PM
dojj's Avatar
dojj
Resident Wrestling Legend
find the wire that powers up when you turn the beams on, then follow it into the lights, they are easy enough to take apart
it's probably a bad earth in the light itself if it's not a bad earth in the loom
Old Apr 8, 2015 | 03:58 PM
Paul_RS's Avatar
Paul_RS
Could be a faulty coloumn switch as well.
Old Apr 8, 2015 | 05:53 PM
Any look PaulT.
Old Apr 8, 2015 | 07:10 PM
P4ULT's Avatar
P4ULT
What is this and where do I find it?
Originally Posted by Glenn_
Any look PaulT.
Not tried yet Glenn, not had time hopefully get a look Friday, just trying to get some ideas.
Not sure if this makes much difference but previously when I tried main beam near side worked and the other went dim.
Old Apr 8, 2015 | 07:51 PM
I take it the fuse is ok and there is power to the fuse.
Old Apr 8, 2015 | 08:34 PM
RichieST's Avatar
RichieST
Sounds like an earthing issue. You need to find where the headlamps earth to and give them a good clean up.
Old Apr 9, 2015 | 06:12 PM
dojj's Avatar
dojj
the bit the light stalk is connected to mate
if you remove the cover (depending on the car it's either easy, non adjustable, or a pain in the arse, adjustable) 3 screws underneath plus one above or 4 screws underneath, 2 that won't come out plus one at the top then move the column adjuster lever to remove the surround
you then have one multiplug and 2 screws, the wiring 'might' be different pre and post facelift cars and the hazzard light switch lens IS different (square on early, round on later cars) so make sure you get this with the replacement
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
3doorcozmess
Sep 7, 2015 01:32 PM
