escort xr3i efi engine swap
Old Apr 7, 2015 | 09:17 PM
chrisgcombi's Avatar
chrisgcombi
Default escort xr3i efi engine swap
Hi all , just wondered if anyone can help . I have an escort 1.6 cvh efi and its making some serious noises . what I need to know is if I swap the engine over to another which I have can I leave the gear box in the car and then also swap the clutch for a new one while its out . thanks
Old Apr 7, 2015 | 09:21 PM
3i Jim's Avatar
3i Jim
10 Year Member
Yes you can.
Old Apr 7, 2015 | 09:34 PM
chrisgcombi
hi thanks for your response , would it be easier to remove up and out , and I would be able to leave driveshafts in ect . thanks again
Old Apr 7, 2015 | 09:45 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
Been a while since I did a cvh but I'm sure it lifts out the top pretty easily without having to remove box and shafts...
I'd take exhaust manifold off to make things a bit easier but just split at gearbox and remove rear engine mount and lift out!
Old Apr 7, 2015 | 09:46 PM
3i Jim's Avatar
3i Jim
10 Year Member
Remove up and out of the engine bay. Can't remember if the driveshafts need removing, it's been a while since I've done one this way.
Old Apr 8, 2015 | 12:42 AM
simonmcf's Avatar
simonmcf
Most suggest dropping the cvh to the floor.
Old Apr 8, 2015 | 06:20 AM
Roosie's Avatar
Roosie
500bhp Cosworth in making
ive always took the cvh out of top with box in place never been a issue if done carefully
Old Apr 9, 2015 | 09:00 PM
chrisgcombi
thanks very much for all your replies
JoeyBoyden
Jan 4, 2024 02:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
Bloody-Fox
Aug 3, 2015 07:48 PM
vdubo7
Aug 2, 2015 08:17 PM
