Toyota supra diff ?
Old Apr 6, 2015 | 10:25 AM
COLEYST200's Avatar
COLEYST200
Default Toyota supra diff ?
Can any of you tell me witch one I need for my setup please . I'm running a 4x4 setup in a focus with a skyline gear box the diff,s are 3.6 at the mo that are in the car but I'm happy to sort a front if I need to go to 3.9 any photos and info of witch one to get and any info ware to get one from would be grate thanks for your time . Ian
Old Apr 6, 2015 | 04:26 PM
Caddyshack's Avatar
Caddyshack
It would be good if you can work out what supra diff matches the 3.6 if you can get one. The 3.9 front diff has a smaller and therefore weaker crown and pinion.
I have gone 3.9 though. My front diff is Bara built with strength plate and quaife atb, that was 1400 built up and shipped inc vat.
Old Apr 6, 2015 | 05:41 PM
MK MOTORSPORT's Avatar
MK MOTORSPORT
hi
the crown wheel and pinion cant both be smaller otherwise they wouldnt mesh
mark
Old Apr 6, 2015 | 06:22 PM
Caddyshack's Avatar
Caddyshack
Originally Posted by MK MOTORSPORT
hi
mark
Very clever
Ok, one is weaker. That is my point. According to Bara. Pinion is smaller
Old Apr 7, 2015 | 02:56 PM
ossie cossie's Avatar
ossie cossie
This type of Diff
Old Apr 7, 2015 | 04:04 PM
Caddyshack's Avatar
Caddyshack
Does 4.56 match the std front then? If so do you know what supra it came from? Yr n model? They all look pretty much the same from the outside
Old Apr 8, 2015 | 10:42 AM
ossie cossie
The ratio in this diff i have is wrong to be 4 wheel drive, but the ratio 3.9 and possibly 3.6 are available here in OZ, i will decide where i am going with it later all i need it for now is to make a bracket to fit it to the beam. I have also seen another for sale on a local gumtree here in Perth OZ i may get that one as well as a spare.
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Fezman1
Sep 7, 2015 09:34 PM
cbminis
Sep 7, 2015 09:42 AM
