what exhaust to go for??????
Old Apr 5, 2015 | 12:14 PM
worm's Avatar
worm
Default what exhaust to go for??????
i have a 2wd sapphire cosworth with 45 k on the clock is is standard apart from koni shocks.im unsure what exhaust to go for the mngoose single pipe 3"system or the twin pipe system oe style i only want a 3"tail as dont want to cut the bumper.it has a twin pipe oe stainless on it but as i have restored the car its not really good enough to match the rest.and also it sounds like a 2.0 gl
Old Apr 5, 2015 | 02:27 PM
fatboy billy's Avatar
fatboy billy
Mine has the single pipe mongoose system with a 3.5" tailpipe and it fits really well and sounds good burbles well but doesn't drone when driving
Old Apr 5, 2015 | 02:51 PM
KSA-Cossie's Avatar
KSA-Cossie
Mongoose
Old Apr 5, 2015 | 03:44 PM
cossie330's Avatar
cossie330
Ive got a Graham Goode Racing one on mine but would like a Mongoose one at some point
Old Apr 5, 2015 | 03:53 PM
worm's Avatar
worm
thanks for the replys guys but wich mongoose do i go for the 3" single pipe or the twin pipe oe style exhaust?
i should say mongoose do both types
Old Apr 5, 2015 | 04:02 PM
worm's Avatar
worm
http://www.ebay.co.uk/itm/Magnex-Exh..._qi=RTM1793729
this one or the single pipe version thankyou
Old Apr 5, 2015 | 04:44 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
I have the single 3" pipe mongoose fitted on my 3dr and can recommend it. Its not noisy by any means but has a nice burble to it for a little 2.0 4 pot motor.
Old Apr 5, 2015 | 05:11 PM
worm's Avatar
worm
Smile
also it is the cheaper option its mosty a standard car but dont want it compleatly grandad spec
Old Apr 5, 2015 | 06:15 PM
Marc sierra's Avatar
Marc sierra
I have the 3" single pipe, but on long drives it can be quite annoying as there's quite a drone coming from the exhaust. At some moments I wish I chose the OE style mongoose.
Old Apr 5, 2015 | 07:22 PM
bigdel's Avatar
bigdel
Magnex all day long. Looks good, fits brilliantly and sounds the part
Old Apr 5, 2015 | 07:46 PM
worm's Avatar
worm
is that the twin pipe oe style thanks
Old Apr 5, 2015 | 08:11 PM
bigdel's Avatar
bigdel
yeah, splits into two after the downpipe, into two centre boxes, then back together for a single rear box.
sits up lovely under the body, much better than the Mongoose I used to have
Old Apr 5, 2015 | 09:01 PM
worm's Avatar
worm
Smile
thanks for that
Old Apr 13, 2015 | 05:06 PM
worm's Avatar
worm
Smile
ordered it today
Old Apr 13, 2015 | 06:22 PM
Matty_C's Avatar
Matty_C
10 Year Member
Does the magnex sit higher up then than a mongoose when fitted? Sounds like it's more speed bump friendly
Old Apr 13, 2015 | 06:37 PM
bigdel's Avatar
bigdel
yep, it fits like a standard system, tucked up nicely under the bodywork. my old mongoose used to drag over every hump, this one doesn't come close
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
