sudden cut out on cosworth
just looking for any ideas on why my cossie cut out while drivin, failure to re sart on toe, left till nxt day and restartd without a problem ,thought mayb fuel pump, but no obvious reason , cheers
Hard to diagnose when it's not actually doing it. Check all your electrical connections and earth points around the car for a start and if u can't find anything have someone follow u untill it does it again and then it'll be easier to find the problem and diagnose it when it's actually got the fault. I would definitely check the fuel pump wiring as its common fault on Cossies if it's a Sierra
When i bought my saff. I could be driving along then it would cut out. The engine would turn over but wouldnt fire. I could tow the car back home leave it for a while then it would run again.
It turned out to be a fuel filter which was blocked. My saff came with a fuel service history but the fuel filter had the date june 1991 on it lol.
wasn't there a thing going around saying its best to hard wire and solder them plug wires together to get rid of problems? Something I remember reading somewhere
Done it again today so I'll need to chk pump, thanks a lot to all for replys
I had this problem as well. Turned out to be a dodgy connector for the fuel pump that sits behind the number plate surround, same one that does the rear numberplate lights iirc. Took aaaaaaggggges to find lol.
I also removed the bulkhead loom plugs - If you are doing it, join on wire at a time - Don't be a hero and chop the entire plug off or you'll be there for ages trying to figure things out
In the end I replaced both the engine and fuel pump looms for peace of mind!
Just wee update wiring to fuel pump was faulty , so thanks to all for replys cheerz
3dr cossie
11
Dec 21, 2015 03:38 PM
Aug 14, 2015 07:29 AM
