Fitting Bigger Valves in a YB
Old Apr 1, 2015 | 10:31 PM
Sonic Boom's Avatar
Sonic Boom
Default Fitting Bigger Valves in a YB
At what BHP level should you be looking at fitting bigger Inlet and or bigger Exhaust valves?
Is it based just on BHP or are there other considerations?
Cheers Rich
Old Apr 2, 2015 | 05:40 PM
Sonic Boom's Avatar
Sonic Boom
Anyone?
Feel free to discuss.
Rich
Old Apr 2, 2015 | 05:56 PM
Caddyshack's Avatar
Caddyshack
I guess some depends on what head work has been done, size of turbo and pressure of boost then the cams too. I.e. Are the valves the limiting factor or is something else restricting flow?
I expect at your power levels big valves will be of benefit. Do you lose torque lower down with bigger valves?
Old Apr 2, 2015 | 06:31 PM
smiley's Avatar
smiley
Found this mate
The standard cylinder is very good. It can support up to 350bhp without modification. For 350-500bhp the valves can remain standard but the ports need to be enlarged to 22.5mm on the intake side and 23mm on the exhaust. For 500bhp+ the valves can still remain standard but the ports need to be made even larger, 25mm inlet and 24mm exhaust and this works well with BD16 inlet cam and BD15 exhaust or BD15 inlet and BD14 exhaust. For 600bhp+ port need to be taken to 26.5mm inlet and 25.5mm exhaust. At this level the valves are becoming restrictive so bigger item need to be fitted. For bigger valves, bigger cams are required and this means further machining of the head
Old Apr 2, 2015 | 07:05 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Originally Posted by Sonic Boom
Anyone?
Rich
I don't have them & have more Power than most.
Old Apr 2, 2015 | 07:19 PM
paul16v's Avatar
paul16v
Monte 087
Thread closed
Old Apr 2, 2015 | 07:28 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
With the power and torque rod had and the way it came in its safe to say if he didn't have them put your money towards something else. But I guess ultimately you can only take the advise of who you use to build your engine. Be it wrong or right
Old Apr 2, 2015 | 07:34 PM
smiley's Avatar
smiley
Thier ya go mate whoever wrote that i posted is talking shit you dont need one
Old Apr 3, 2015 | 11:34 AM
Sonic Boom's Avatar
Sonic Boom
So we're going with you don't need larger valves at any point when tuning a turbo'd YB and I presume they are only necessary for the N/A boys?
Rich
Old Apr 3, 2015 | 01:08 PM
Caddyshack's Avatar
Caddyshack
Would make sense on na engine as there is no boost to push the air in
Old Apr 3, 2015 | 01:28 PM
Mark Shead's Avatar
Mark Shead
Rich
800hp or above you will start to have gains and losses going bigger.
Mark
Old Apr 3, 2015 | 05:30 PM
Sonic Boom's Avatar
Sonic Boom
Mark
Cheers Mark so is Rod's new spec going to have larger valves?
Rich
Old Apr 3, 2015 | 05:58 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Rich
No it will not.
Old Apr 3, 2015 | 06:15 PM
Sonic Boom's Avatar
Sonic Boom
No it will not.
So you can easily run 1000bhp with standard valves?
Good to know
Rich
Old Apr 3, 2015 | 06:31 PM
Mark Shead's Avatar
Mark Shead
Good to know
Rich
We havent easily done a 1000hp yet and most likely be very hard.
Mark
Old Apr 3, 2015 | 07:51 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Good to know
Rich
Wow!! that would be good.
As with all engines its a compromise. We could fit bigger Valves, larger Ports & a wild exhaust cam but it would do nowt below 6k. Its about Gains & Losses. We want a road engine not a drag engine & that will be tough.
The head has .25mm bigger Ports & a stage wilder exhaust cam. We hope to follow the existing curve up to 6k then the Huge Airpump we strap to the engine will be asked to puff circa 4bar ( 58psi) to increase the Torque above 6k. If we see 656ft/lb at 8k the Dyno WILL show 1000bhp. The Maths don't Lie but it may be hard to achieve.
Old Apr 4, 2015 | 02:42 AM
Sonic Boom's Avatar
Sonic Boom
I used the word "easily" flippantly but what I was trying to convey is there is no need for larger valves on pretty much ant turbo'd YB application.
Rich
Old Apr 4, 2015 | 08:05 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Rich
That's correct.
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
rsstav
Aug 11, 2015 04:22 AM
Red_bull
Aug 9, 2015 08:34 AM
lockie
Jul 31, 2015 10:03 PM
