Afr readings ?
What should the afr gauge be reading at idle ,cruising, and on boost
Can't get car in for rolling road session till may so want to know what should be reading till then
PassionFords Creator
Purely a rough guide but reasonably safe for mooching around...
13-14 AFR at idle and low load
12-13 AFR under light to medium load
11-12 AFR under very high load.
Your mapper will correct from there for safe hard use.
Cheers bud just booked it in with you in may
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
