Ecu problem
Hello,
I bought the lc als wasted spark chip and board, i fitted it to my ecu and i have issues it seems the two yellow relays dont start and i have constant spark when i power the car not turn on the car just the electrics, also i spot a problem in the board you will see in the pics. If the ecu is dead can i save the chips and put it in other l8 ecu i have plenty. Does anybody know, got the same problem? What could cause the ecu failing?
With a another standard l8 the relays engage so i have power on fuel pump which i didnt and everything seems fine
Does anybody know how will i get signal for the tachometer? i have connected the grey wire of the wasted spark in pin 21 but my car has air con should i connect it to pin 9 and cut the pin? if i do that so i reconnect the 21 pin back? thanks in advance
DixieTheKid
11
Jun 6, 2020 11:20 AM
DixieTheKid
Sep 14, 2015 09:04 PM
