s2 only running on 3
Old Apr 2, 2005 | 01:56 PM
rick1's Avatar
rick1
Default s2 only running on 3
just started rs 2day after full engine rebuild.was runnin ok cold but dont
wana run when hot plus only on 3 cylinders.plugs r ok leads r ok.im not 2 clued up on the fuel side of things.any 1 got any advice 4 me.
Old Apr 2, 2005 | 06:23 PM
Rs1's Avatar
Rs1
Do a compression test first,all cylinder should be equal (+/- 5%)
Whilst its running pull a lead off(one at a time)and note the engine tone.The one that doesnt change the engine tone when you pull a lead off is the cylinder at fault.
Losing a cylinder could be down to faulty spark plug,faulty leads,rotor arm or dizzy.
If these are ok its probably not gettin fuel(or not enough,or bad spray).Could be an injector blocked or a metering unit fault.
Old Apr 2, 2005 | 06:25 PM
KSA-Cossie's Avatar
KSA-Cossie
were the plugs new,did you gap them correctly ??
Old Apr 3, 2005 | 10:56 AM
rick1's Avatar
rick1
plugs are new didnt gap them didnt think u had 2.i have found that it is cylinder 1 that is down.how do u no if its an injector.plus plugs were black think its runin 2 rich
Old Apr 3, 2005 | 01:17 PM
Moonie's Avatar
Moonie
Have you tried No1 plug in another cylinder, see if the misfire moves to that cylinder, this will eliminate the plug being at fault
Old Apr 3, 2005 | 04:19 PM
s3rst's Avatar
s3rst
generally all plugs that say there pre gapped need checking and re gapping ;)
also if running rich on that cylinder it points to poor spark. check gap and try again
Old Apr 3, 2005 | 04:31 PM
KSA-Cossie's Avatar
KSA-Cossie
Any luck m8 ?
Old Apr 4, 2005 | 06:04 PM
rick1's Avatar
rick1
plugs are ok leads are and injectors are to starting to think i got worped head.to be honest it was only on 2 half.gettin head checked 2moro 2 be on safe side.its runnin well rich.
Old Apr 8, 2005 | 05:01 PM
rick1's Avatar
rick1
found prob 7 bent valves.when i bought car bottom end was nakerd but the bloke said he had head rebuilt so i took his word bein a plank.problem solved hate people that lie.
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
