Glowing battery light.
I'm sure I read something on this before but had no luck searching. Something about a blue wire?
Anyway, Battery light is glowing slightly and illuminates when braking or using the windows.
Car recently had a new alternator and is reading 13.6 volts at the battery.
The blue wire goes from the battery light to the alternator and is what excites the charging circuit, if this is broken you will get no charge at all.
I would suspect either the live wires from alternator to battery (via starter) or the main earth's including the starter earth (biggest one on the car).
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
