Ford KUGA Talk about the Ford Kuga here!
Red light flashes on dash when driving
Old Mar 18, 2015 | 09:20 AM
Darren1593's Avatar
Darren1593
Zetec-S
Default Red light flashes on dash when driving
Has anyone ever had the red light flashing on the dash board whilst driving a ford kuga ? Done it yesterday whilst driving home but not done it again since ?
Cheers Darren
Old Mar 18, 2015 | 09:32 AM
RichieST's Avatar
RichieST
What red light is it? There's got to be over a dozen to choose from....
Old Mar 18, 2015 | 09:34 AM
Darren1593's Avatar
Darren1593
Zetec-S
It,s the one right in the middle between the temperature and fuel gauge
Old Mar 18, 2015 | 09:43 AM
RichieST's Avatar
RichieST
Presuming you mean the immobiliser warning light. No it shouldn't do this, it has registered a fault. Was it flashing steadily or giving you a code with a series of flashes followed by a pause?
Old Mar 18, 2015 | 09:48 AM
Darren1593's Avatar
Darren1593
Zetec-S
It flashed steadily for 5-10 seconds then stoped for a few seconds then flashed four times, done that a couple of times. There are no messages or anything on the screen
Old Mar 18, 2015 | 09:54 AM
RichieST's Avatar
RichieST
Could be a communication fault with the key. Does it have keyless start with the push button or is it a normal ignition switch. I'd get it looked at, it should have stored an error code in the alarm's ECU.
Old Mar 18, 2015 | 10:01 AM
Darren1593's Avatar
Darren1593
Zetec-S
Has keyless entry and start. I have chnaged the battery in the key as it came up that was low just 10 mins ago. Could it have been something to do with that ?
Old Mar 18, 2015 | 10:34 AM
RichieST's Avatar
RichieST
I have had that low fob battery error on mine before but it just comes up on the dash display, the immobiliser light doesn't flash with it. Probably just see if it happens again, if it does get it looked at.
Old Mar 18, 2015 | 10:40 AM
Darren1593's Avatar
Darren1593
Zetec-S
Cheers buddy 👍
Old Dec 27, 2015 | 04:11 PM
melpear's Avatar
melpear
I have had the same problem on my Ford Focus Titanium 2010,old shape. Intermittent flashing of red light above warning light, have changed batteries in keys, no change. Mine is a keyless system.
Old Aug 17, 2017 | 07:12 AM
MathewJ's Avatar
MathewJ
Default Same Issue with 2010 Ford Focus
Hi, I know this is an old thread, but I am having a similar issue with my 2010 Focus. Even when I am not driving, the immobilizer light will flash once and the radio will display "Ford Audio" as if I just turned it on. This happened a few times and I put it down to radio signal, but now it is occurring more regularly. There is also a clicking sound.
I have noticed a crack in the reverse light lens though and where I live we have had a lot of rain lately, so could this be the cause?
Thanks
Old Sep 8, 2017 | 03:56 PM
deathrider666's Avatar
deathrider666
Damn Cars
Same here, 2010 Focus Titanium 2.0 tdci, red light will flash on randomly now and again, no pattern, stereo sound has a little hiccup when it comes on but no other side effects.
Old Sep 9, 2017 | 08:50 AM
MathewJ's Avatar
MathewJ
I am taking my car back to the garage I bought it from on Monday, so once they work out the problem, I will let you know
Old Sep 15, 2017 | 12:08 PM
MathewJ's Avatar
MathewJ
Just got the car back fro the garage this morning and they said the issue was with a faulty earth in the fuse box? so they have fixed this and now the car seems to be working fine.
Hope this helps.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Alun Gregory
Sep 6, 2015 09:40 AM
Timmy74
Ford Mondeo Including ST
Aug 28, 2015 01:21 PM
dojj
15
Aug 18, 2015 08:21 PM
Bailes1992
Aug 16, 2015 07:14 PM
