Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
T5 speedometer plastic gear needed
Old Mar 13, 2015 | 07:22 PM
Sierrasideways's Avatar
Sierrasideways
Default T5 speedometer plastic gear needed
One of these I need if anyone can help me out:
Please let me know if you have one for sale, needed as soon as possible
Thanks.
Philip.
Old Mar 13, 2015 | 10:07 PM
RIB1122's Avatar
RIB1122
none of them are a cossy one!
cossy have two types one held in with a clip and the other with a ball and circlip
so what do you need?
Old Mar 13, 2015 | 10:18 PM
Sierrasideways
Just ripped a pic off Google!!!
I honestly don't know as mine broke inside the gearbox and is probably in a million pieces
You seem knowledgable on the subject so maybe you could enlighten me?
I'll buy both if you know where I can get them.....
I tried Ford today (not expecting to find anything but always worth a shot) and there is apparently none in any Ford dealership in Ireland, UK or Europe. They searched for a Sierra Cosworth 2WD box too so anything from 83 to 91 roughly.
Philip.
Old Mar 13, 2015 | 10:43 PM
RIB1122's Avatar
RIB1122
they are a fortune mate so doubt you will buy both!
Old Mar 13, 2015 | 10:51 PM
Sierrasideways
Sound, I was expecting that.
Don't suppose you know of one about mate?
Old Mar 22, 2015 | 01:02 AM
Toe Knee's Avatar
Toe Knee
Doubt you will get one anywhere mate unless someone breaks a box I was looking for one too, early boxes has the clip later had the ball and circlip.
I managed to get the later one and have had to make it fit, they come in a browny colour.
Those pictured look very similar though as long as the ID is the same and amount of splines it will still work, what were they off of?!
Also I doubt it has broken as such just sounds like it has come loose off the shaft so probably the early type you will have to take the end cover off to have a proper look may just need a new clip!! Which are also rocking horse shit
Old Mar 22, 2015 | 09:45 PM
Sierrasideways
Thanks for the reply mate.
I bought another box with the speedo gear on the shaft, the brown one
Indeed the one in my car had broken off in bits. Happened my old gearbox too
Hopefully will get the box swapped soon.
Thanks again for the help, it is much appreciated.
Philip.
James Porter
Aug 26, 2015 10:51 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
borboyous
Aug 22, 2015 11:17 AM
muffster
Aug 12, 2015 08:14 PM
col93saphcos
Aug 7, 2015 03:21 PM
