Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
revs drop when slowing
Old Mar 11, 2015 | 10:11 PM
sgilwhite's Avatar
sgilwhite
Default revs drop when slowing
hi had this issue for a while:
only when the engine has got to temperature does this happen....when i am driving and the car slows to a near stop with or without braking, sometimes the revs will drop a little too low and there is a rumble before the revs rise again. it doesnt do it all the time, about 4 days out of 7 id say.
it only happens when the engine gets to operating temp,
it does it only when slowing with our without braking,
thought it was a faulty sensor (maybe crankshaft) as it was intermittent,
cannot find vacuum leaks and or problem with exhaust,
have changed idle control valve and throttle position sensor,
have done an ecu reset after i changed the idle valve,
have checked for error codes and none came up.
any ideas? the only thing i can think of is to check the tps in case it is set too low.
Old May 5, 2015 | 05:06 PM
Dekkb's Avatar
Dekkb
stuck with the basic
similar thing on mine, think its either the air flow sensor or the mixture control (apparently). bloody annoying as I thought it was the fuel pump 1st time and fitted a new one.
Becka674
11
Oct 8, 2015 03:11 PM
Chas
Oct 5, 2015 07:13 PM
A.t.p
Sep 29, 2015 05:04 PM
Marv888
Sep 26, 2015 03:44 PM
