mondeo 1.8 duratec smoky
Old Mar 11, 2015 | 01:12 PM
zamp's Avatar
zamp
Default mondeo 1.8 duratec smoky
Just taken my car 03 mondeo 1.8 petrol for its pre mot and the bloke says I am not going to be able to get it through the emissions due to it giving out a lot of blue smoke at about 3500rpm when you hold the throttle for a minute or 2.he says he has seen it before but isn't sure what causes it and in the past hes advised replacing the engine instead of spending time trying to solve it,seems a shame to scrap the car as it drives great and is still good on fuel etc
anyone know what causes it? and is there a quick/cheap fix?
it has done 125000 miles,hes says he has seen it happen at 70000 on other ones though
Old Mar 11, 2015 | 01:32 PM
3i Jim's Avatar
3i Jim
10 Year Member
Duratorq is the Diesel engine. Anyway, have you noticed it loosing oil? It could be blocked breather pipes, worn piston rings, worn bores. Best to do a compression test and inspect the breather pipes. Could use a bore scope to inspect the bores. If the rings or bores are worn you're best of putting in a good second engine in or scrap it.
Old Mar 11, 2015 | 01:59 PM
zamp's Avatar
zamp
sorry,duratec i meant
doesnt seem to be using a great amount of oil really
Old Mar 11, 2015 | 02:21 PM
3i Jim's Avatar
3i Jim
10 Year Member
Give it an oil change and pour in some Wynn's stop smoke. It might work.
Old Mar 12, 2015 | 05:28 PM
cossie09's Avatar
cossie09
hi mate,had the same thing on a 02 1.8 petrol...it was the egr just blanked it of and it was 100%[it only had 53000 mile on it,]cheers
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
