Cosworth Parts For Sale / Escort and some 4X4 Saph - Updated more bits 04.04.15
Hi folks, having a bit of a clearout here. Here's some bits that I'm not going to use on my resto, in most cases because I've duplicated parts or don't need them. Some rare bits here now.
Anyway....
Pair of good front door card speaker grilles £15 delivered.
Pair of front door pockets, the fuzzy ones. £40 delivered.
Pair of rear shafts. These are off my own car which has only done 36k miles. Could do with a clean up but apart from that in good nick £70 delivered.
3 sets of dash clocks, I would say these would be useful for spares myself £30 a pair delivered. MIDDLE SET SOLD.
Ford centre caps. These are gel Ford badges mounted to aftermarket centres. Good condition. £15 delivered the 4.
Rear speaker blanks £15 delivered the pair.
Rear wheel flanges. Refurbed and studs removed. Painted with Simoniz tough black on the backs. Come with 8 brand new longer studs that need to be fitted. I've put grease on the fronts to stop rust which will need to be removed before you fit them. £45 delivered.
Pair of rear stub axles. As you see them here £55 delivered the pair.
Now you don't get much rarer than this, centre console ashtray mount, in mint condition, as you see it here £35 delivered.
Genuine Creative Carbon matt carbon n/s passenger side hockeystick, scraped a bit on the lower side and a bit of cracking £20 delivered. This would be good actually rubbed down and painted satin or matt black. I bought this brand new originally.
Door mirror interior mount and switch, £15 delivered.
Original shock top mounts £10 delivered. I might paint these if no-one buys them.
Power steering tank. The same as standard Escort Cossie but it's not a screw top one. Complete with cap £15.00 delivered.
Morette lenses. Here I've got a pair of glass for the inner lights and the light units for the outer lights, including the adjuster screws. The silver part of the outer lights is rusty though on both. Great for the glasses or adjusters though, £45 delivered the lot.
One front speaker grille, in good condition £7.50 delivered.
Original horns, off my own car. £15 delivered.
Two sets of steering column shrouds. £30 each delivered. Might need to check dimensions on these because small and big turbo are different I believe.
Pair of inner door pulls. £15 delivered the pair.
Heater Control panel. This is not an Escort Cosworth original one, the main difference is the pocket rather than the clock area, although you can remove that section and fit the clock if you're careful, I've done it myself in the past but it does take patience. £30 delivered.
Two pairs of rear lamps, not the fairest in the land but they are proper Ford (Non-German) ones and there's no bits missing. £30 each a pair delivered. ONE PAIR SOLD.
Big Ford badge, in really nice condition £12.50 delivered.
Any enquiries or questions welcome. pm me or you can mail me direct on tjatkin@ntlworld.com
Anyway....
Updated list. There will be more to come and anyone that fancies a job lot give me a shout, tell me what you want and I'll give you a price.
JoeyBoyden
Jan 4, 2024 02:36 PM
rog
Sep 4, 2015 12:10 PM
Aug 14, 2015 07:29 AM
