Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Help Please Someone, ST170 no power 😞
Old Mar 2, 2015 | 06:31 AM
mickparky81's Avatar
mickparky81
Default Help Please Someone, ST170 no power 😞
Hi. Please oh please can someone help me with this, I am getting a loss of power when the car warms up. Cold its fine goes like a rocket but its as if as soon as the auto choke goes off, its coughing spluttering under hard acceleration, pick up is slow and if I'm going up hill I might as well get out and walk. I'm losing the will to live with it now, here's a list of what iv tried changing:<br />
Fuel filter (new)<br />
Fuel pump<br />
Pump driver module (new)<br />
Spark plugs (new)<br />
Leads<br />
Coil pack <br />
O2 sensors (new)<br />
Air flow meter<br />
Timings been checked<br />
De-cated<br />
The non new parts were removed form a good running car. My code reader come up with o2 sensor and timing is retarded but timings been checked and is fine. The only other query I have is plug 3 has a erratic spark, if you pull the lead off the coil pack end it sparks fine, pull it of the plug and it is hit and miss spark. But that happens when its cold or hot and iv swapped the pack and leads and both sets do the same. Iv also checked the plastic bit on the side of the inlet manifold for the control runner for turning 90 degrees on start up and it is doing it. Next on my list of things to change is fuel pressure sensor and cam sensor.<br />
Any help, advice would be much appreciated. Thanks
Old Mar 4, 2015 | 06:56 AM
mickparky81
Iv also cleaned the PCV (wasn't blocked and moved freely anyway) and the breather to the throttle body is clear. Any suggestions? Please😭
Old Mar 4, 2015 | 07:39 AM
STeve's Avatar
Super Moderator
you have covered all the main problem areas, I would personally stick in for diagnostics session before throwing anymore money at it and let them tell you whats up
Old Jun 21, 2017 | 09:33 AM
PiotrST170's Avatar
PiotrST170
Hellow, did you resolved this problem ?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Iain Mac
Sep 30, 2015 09:39 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
