Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
ford fiesta 1.4 zetec 2003
Old Feb 28, 2015 | 02:07 PM
Fiesta Steve's Avatar
Fiesta Steve
Default ford fiesta 1.4 zetec 2003
Help required please. Purge valve (EVAP) I have a problem with my cars idle, have tracked it down (hopefully) to this valve. I have measured the resistance across the valve terminals at 31.5 ohm, what voltage should there be across the supply connector, I have measured 1.9v across them. Have tried a replacement valve with no joy, engine will not idle. I have since disconnected the 2 pipes from the valve & joined together , the car runs perfectly. I have no engine management light on.
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Botts
Aug 13, 2015 04:16 PM
