COSWORTH parts clear out lots
Old Feb 22, 2015 | 01:38 PM
mick mex's Avatar
mick mex
Default COSWORTH parts clear out lots
T4 turbo, als Miriam shaft minimal play in shaft. Been mounted on 4x4 manifold so studs removed and drilled out £950
P8 ECU als enabled board,chip for t4. Standard comp,bd 14's,55lbs Siemens ,rally spec will not power up fuel pump from ECU £
425
Level 8 ECU pectal board, t34, low comp ,greys, again rally spec won't power fuel pump from ECU £300
2x t5 bell housings £65 each
3x pf09 throttle switches £55 each
Turbo damper £50
4x4 fuel rail and regulator,'6 fitting welded to rail £55
Msd level 6 chip,greens t34,standard comp, cams £50
2x air injectors £225 per pair
Pectal p8 board issue 1 £50
2x blue plug lead sets £ 35 set
2x sapphire cooling fans and brackets £25 each
Oil beather weld on fittings £35
Coolant swirl pot £25
New 1 grey injector £40
Bottom pulley ,outer v machined off £65
Rs500 copy alternator dropper bracket £20
Als throttle body and idle valve. £85
New old stock 2wd clutch centre plate £15
4x4 intercooler, removed from mk2 rs2000. £25
Large stainless boost and coolant clamps job lot £20
Ignition amp and bracket £25
All parts plus postage exept turbo collection only,Guildford Surrey
Any more info needed give me a call 07734436787 thanks Mike
Old Feb 22, 2015 | 02:24 PM
Acac's Avatar
Acac
Could have the swirl pot please , how much posted to pe15 .
Old Feb 22, 2015 | 05:21 PM
7unner172's Avatar
7unner172
ill take this mate
Old Feb 22, 2015 | 05:53 PM
mick mex's Avatar
mick mex
Default Cosworth parts
All pms replied
Old Feb 22, 2015 | 07:49 PM
tessatony's Avatar
tessatony
Default boost clips
are the boost clamps normal jubaly clips
Old Feb 24, 2015 | 07:27 AM
mick mex's Avatar
mick mex
ill take this mate
I have pmd you payment details. Thanks mike
Old Feb 27, 2015 | 10:19 AM
mick mex's Avatar
mick mex
Default N
425
Turbo damper £50
PARTS SOLD
Breather
Ignition amp
Pipe clamps
1 pfo9
Coolant swirl pot
The rest now on fleabay
steerfromdarear
28
Jan 29, 2016 06:14 PM
The Enigma
13
Aug 20, 2015 09:38 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
Adam-M
22
Aug 10, 2015 10:46 AM
