audi a3 warning lights problem
Old Feb 16, 2015 | 07:57 PM
geordiegooner's Avatar
geordiegooner
Default audi a3 warning lights problem
any audi techs can help with the following problem ive encounted with my 55 plate audi a3 sportback.I changed the battery the other day and since that the srs and yellow steering wheel light has come on the dash,i googled it and said low battery voltage so I got another battery from graft but still no joy as lights still on and steering seams more heavy.any help would be gratefull.
Old Feb 16, 2015 | 08:06 PM
Oranoco's Avatar
Oranoco
Have you scanned it with VCDS? The codes may need to be cleared down.
Old Feb 16, 2015 | 08:15 PM
geordiegooner
I don't have any fault scanning tools,but car was perfect before changing battery.
Old Feb 16, 2015 | 09:34 PM
jamie's's Avatar
jamie's
Will prob need the steering angle sensor calibrated if the battery's been off
Nothings simple on modern cars, even just a simple battery swap can cause probs
Old Feb 17, 2015 | 04:34 AM
3i Jim's Avatar
3i Jim
10 Year Member
Have you driven the car since fitting it? Some cars need to be driven to recalibrate and then the lights will go out
Old Feb 17, 2015 | 06:45 AM
mat_rss2's Avatar
mat_rss2
They should go off after being driven, they re-calibrate themselves
Old Feb 17, 2015 | 09:36 PM
geordiegooner
hi yes its done 10-15 miles and still on everything was spot on till swapped battery
Old Feb 17, 2015 | 10:07 PM
Fullflush's Avatar
Fullflush
It should sort itself out after about 5 mins of driving.
You need to scan it for codes
Old Feb 17, 2015 | 10:26 PM
markk's Avatar
markk
Try full left hold it over for 3 secs, full right 3secs then centre the wheel.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
dojj
15
Aug 18, 2015 08:21 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Neatrags
Aug 16, 2015 07:57 PM
M K
Aug 12, 2015 06:57 PM
