Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Fuel consumption after service.
Old Feb 15, 2015 | 01:25 PM
pjaj's Avatar
pjaj
Unhappy Fuel consumption after service.
I have a 59 plate 2 litre TDCi Titanium estate with 48,000 on the clock.
It gets serviced once a year in late Autumn as I do less than 12,000 miles per year. 16 months ago, after service, I noticed that the fuel consumption dropped to the low 40s MPG per tank, but after some months went back to its previous level of around 46-49 MPG per tank (and over 50 on long runs). This year exactly the same has happened, serviced about 4 months ago - poor fuel consumption ever since even on longish journeys. I can't get it above 43MPG however carefully I drive.
I can think of a few reasons, including
  • The garage didn't reset something.
  • New oil is thicker than 12,000 mile old oil - more drag.
  • Winter weather is colder and damper.
Any ideas what might be the real reason?
Old Feb 15, 2015 | 05:10 PM
steve-26's Avatar
steve-26
Would of thought you mite use slightly more fuel in winter due to heaters lights and choke being used a lot more.
Old Feb 15, 2015 | 09:28 PM
pjaj's Avatar
pjaj
Thanks, but I shouldn't think so, because the drop in fuel consumption occurs immediately after the service not progressively as the weather gets colder and the nights draw in. It's not a gradual process.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
